How to Disarm Alarm System for cross-country auto transport?
2015 DODGE DURANGO
99,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
AUSTIN_CRAFTS
How do I disarm/disable the alarm system in my vehicle listed above for cross-country auto transport? I need to prevent my car alarm system from going off during the duration of the trip on the auto transport carrier.
Feb 19, 2024 at 5:57 PM
STEVE W.
  • 15,115 POSTS
The alarm on that vehicle from the factory won't be an issue as long as the transporter has the key or fob. The simple method is to not lock the vehicle. Next would be that once loaded they lock it with the key or fob. Then they unlock it the same way. That truck only has an alarm system that senses intrusion so unless they pry open a locked door it shouldn't go off. Now if it has an aftermarket alarm you would need to look at the instructions for whatever system is installed.
Feb 20, 2024 at 8:31 AM
AUSTIN_CRAFTS
If I took out the fuse for the anti-intrusion module it shouldn’t go off at all, correct?
Feb 20, 2024 at 9:38 AM
STEVE W.
  • 15,115 POSTS
There is no individual fuse for the alarm system on that vehicle, it is all part of the body control module. Remove the fuses for that and the doors will not lock, and the vehicle will not run. In reality I have never seen those systems be a problem because the hauler has the keys with them.
Feb 20, 2024 at 10:04 AM
AUSTIN_CRAFTS
Thank you!
Feb 20, 2024 at 10:07 AM
STEVE W.
  • 15,115 POSTS
You're welcome. If it were mine, I'd walk around it taking pictures, then sign the paperwork and hand them the keys. When it gets to the new destination, compare the pictures to check for damage and if it's okay go and enjoy it.
Feb 20, 2024 at 10:19 AM
