Yes they can get into the inlet side, but then they hit the cabin filter which means they can't get inside the car itself. Most cars have an inlet screen on the outside as well that blocks larger items. Others don't. Easy way to tell would be to replace the cabin filter. It's behind the glove box. You empty the glove box out, then remove the two stops from the holes and disconnect the damper on the outside. Then drop the box down and release the clips on the cover. Now look at the filter for the airflow direction. Then remove it. Look it over for any damage or signs of critters. Install the new one with the arrow pointing the correct direction. Install the cover, put the glove box back together. Throw out the 2-year-old tootsie rolls, and leaky pen (lol) then enjoy. FYI if you can find them, they make a carbon filled filter for many cars as well as baking soda ones. I use those rather than a stock filter as they can help if you go through areas with dubious air quality. I used to drive past a rendering plant and in the summer, it got really bad. The baking soda one helped with that.
May 27, 2025 at 10:02 AM
