My vehicle showed sluggish response to acceleration for a quick pass and then a few moments later, threw a check engine light with restricted performance indicator image on instrument cluster. I came off the highway to a neighborhood street and the vehicle began showing signs of misfire with limp mode like performance. I took it to Orielly's, got the codes read. Every cylinder misfire code displayed, some other codes for camshaft and sensor codes, O2 codes, transmission module code, ECM code, etc. Some are from previous events that were corrected but still presenting codes from internal code archives I imagine. I removed plugs and coils. Cleaned carbon off plugs, reattached them and coils, checked all electrical connections to ensure they made reconnection, and cleaned mass airflow sensors, replaced air filters, hooked up battery jumper since battery drained during the few troubleshooting days i was checking vac lines, wires, performing tune up on vehicle, and vehicle wouldn't start. Unhooked battery, unhooked MAF sensors, and Next day vehicle did start on jump but quickly puttered down to stall. The exhaust isn't plugged, so figured it must be fuel filter, as I used 87 Oct for a few fill-ups during a few weeks I was crunching a tighter budget. Vehicle ran strong prior to breakdown event. Can't find a single image or video for location or instructions to location for my vehicle listed above hse lux 5.0 L gas v8 4wd automatic L322 model generation SUV. Did a Google search with VIN, SALMF1D49BA340658 and still can't get specific requested results. I saw an image for another model that I clicked to reference their search parameters and saw your site. Hope you can help.
May 7, 2023 at 5:50 PM
