Direct wire rear defrost
1998 BUICK PARK AVENUE
190,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
DCKELLEY
  • 125 POSTS
i'm wondering if i can bypass the antenna module and directly wire rear defrost? i don't have a lot of cash right now and frankly i listen to the radio rarely. Thanks, Don
Jan 10, 2019 at 9:37 PM
Good morning,
No, that would be a bad idea. The rear defogger is on a timed circuit. the antennae is a constant circuit. This means you can overheat the rear window and run the risk of fracturing the glass from too much heat.
Did you check the fuse for the rear defogger?
Make sure the fuses to the HVAC system in the fuse panel have power on both sides with the key on. The control head for the AC module controls the activation of the rear defroster and also controls the time based on ambient temperature.
The heater and A/C programmer receives the rear defogger request from the heater and A/C control assembly. The heater and A/C programmer will then send a Class 2 message to the body control module (SBM). The SBM will control the rear defogger on/off status and the amount of time that the rear defogger is on. The SBM will communicate the rear defogger status to the heater and A/C programmer over the Class 2 serial data and the heater and A/C programmer will light the rear defogger indicator accordingly.
Jan 11, 2019 at 5:44 AM
DCKELLEY
  • 125 POSTS
thanks Roy, i didn't think about the timer. i did pull the large 40 amp fuse (it looked fine). I'll need to check the one under the dash next.
Jan 11, 2019 at 8:15 AM
Okay, let me know.
Jan 11, 2019 at 8:17 AM
Did you reply? I see you posted but nothing came up?
Jan 11, 2019 at 8:25 PM
DCKELLEY
  • 125 POSTS
i deleted a comment that i meant for my other post. sorry about that.
Jan 11, 2019 at 8:27 PM
No worries. Wanted to be sure I did not miss something
Jan 11, 2019 at 8:32 PM
DCKELLEY
  • 125 POSTS
in my book/manual it says the fuse under the dash that controls the defog relay is the one marked IGN SEN. pulled and it looks fine. is there another fuse under the dash i need to look at?
Jan 17, 2019 at 11:30 AM
I attached the diagram for you to view. Check the 40 amp fuse.
Jan 17, 2019 at 11:40 AM
DCKELLEY
  • 125 POSTS
I also looked at every other fuse that was marked for HVAC, all look okay. next under the rear seat and that relay?
Jan 17, 2019 at 12:02 PM
DCKELLEY
  • 125 POSTS
And the 40 amp under the hood.
Jan 17, 2019 at 12:03 PM
Yep, test for power on both sides with either a test light or voltmeter.
Jan 17, 2019 at 12:49 PM
DCKELLEY
  • 125 POSTS
I am getting a bit out of my league. I've never used a volt meter before. so many settings. i know it would be a good thing to learn to use one of these. I've always wanted to. can an old dog learn a new trick? volt meters for dummies, here i come. :)
Jan 17, 2019 at 5:01 PM
Sure, let me attach a guide for you.
Jan 17, 2019 at 5:07 PM
DCKELLEY
  • 125 POSTS
volt meter and multi-meter not the same. volt meter is a test light right? sorry i feel i'm taking up too much of your time. i'm off to learn a bit and will get back to you.
Voltmeter and multi-meter are the same things.
Jan 18, 2019 at 3:03 AM
DCKELLEY
  • 125 POSTS
I'm with surprised how easy reading one of these is. thanks for the link. will be quite cool this week. will get back to you next week. thanks for all the help. Don
Jan 18, 2019 at 6:54 AM
You are welcome.
Always glad to help.
Jan 18, 2019 at 8:04 AM
