Dipstick tube broken where it connects to engine
2004 VAUXHALL AGILA
88,000 MILES • 1.0L • 3 CYL • 2WD • MANUAL
KWOTHERSPOON89
Tried to fit new one today but the new one only going into engine a little bit then it's like something is blocking it? How can I fix this as cheap as possible?
Jan 17, 2020 at 4:23 AM
SCGRANTURISMO
  • 4,897 POSTS
If the broken piece of the old dipstick tube is still in the engine block then that will need to come out before you can install the new dipstick tube. I would recommend trying to remove it with a pair of long needle nose pliers. Please get back to us with how everything turns out.
Thanks,
Alex
2CarPros
Jan 17, 2020 at 4:42 PM
KWOTHERSPOON89
I tried the long needle nose pliers to no success. Anything else I could try or am I better taking it to someone who knows what they are doing?
Jan 19, 2020 at 3:11 AM
STEVE W.
  • 15,113 POSTS
Okay try this: Take a coat hanger or other stiff wire, cut it and form a shallow short hook on one end, the hook needs to fit into the tube and let you hook the bottom of the broken off piece to fish it up out of the hole far enough that you can grab it with the pliers.
Jan 19, 2020 at 5:02 AM
SARAHMOTOR
I have got an old guide out and blocked hole, but I can't find replacement dip stick guide for Agila 2007. I have tried all car spares and Vauxhalls, but nothing is available. Any suggestions?
Apr 12, 2022 at 8:03 AM
STEVE W.
  • 15,113 POSTS
That car is a rebadged Suzuki Wagon R+, you might try a Suzuki dealer and tell them you need a dipstick to fit the engine you have in the car. If you have the original pieces of the old one you might be able to have one made to fit, even simple brake tubing cut to length and installed would work as a housing as long as it fit's tight and seals. To make one wouldn't be all that hard, you would install a longer version of the tube, then drain the oil and remove the filter just like doing a service. Add in the correct amount of oil, start the engine and let it run for a couple minutes. Now insert the dip stick, pull it and see if you are touching the oil yet, if not slip a piece of wire in and keep checking it every centimeter, Now use it to cut the tube and install the stick again, measure the oil level between what you touched and the full mark and cut that much off of the tube. Now when the dip stick is inserted it should read full. Add a brace to make it stabile and hold it in the engine.
Apr 12, 2022 at 12:10 PM
