Dim sidemarker, low beam headlamp and turn signal
2006 CHEVROLET IMPALA
150,000 MILES • AUTOMATIC
MIKEREY
I have 2006 chevy impala the passengers side sidemarker, low beam headlamp and turn signal are both dim the only one that stays on as normal is the hi beam headlamp. Replaced the bulbs and checked the fuses. Not sure what else to do?
Jan 11, 2014 at 4:51 PM
CARADIODOC
  • 34,306 POSTS
Bulbs don't get dim. They work or they don't. What you're describing is typical of a broken ground wire. GM has had some really bizarre headlamp circuits, but in general, if you have a dim right low beam, it will go out completely if you unplug the LEFT headlamp bulb. That works on all other car brands. Due to their weird daytime headlamp circuit, that might not work on your car, but it's worth a try. Also, unplugging the right headlamp bulb might make the side marker light go out. Any observations like that point to a ground wire problem. The most common place to find the break is where all the ground wires for those bulbs are spliced together or are bolted to the body.
Jan 11, 2014 at 5:01 PM
