Super Duty Senior Bus. Has many running (marker lamps). Recently they all went dim. The pull switch has been tested using the book for continuity and the connector for the headlight switch was jumpered to test the running lamp circuit.
At a rear bulb socket, a meter shows 5 volts.
A 20' test wire lead was run from the battery, terminal to a marker lamp area to use as a ground to test for voltage at the connector which is 5 volts
That same test lead was connected to the + terminal of the battery to inject 12 volts into the + pin of the marker light harness. all the marker lights lit up brightly. except for the 2 in front (stock). those seem to come on with the switch and others all together. (5v, crap)
the b2 terminal of the wire harness for the headlight pull switch is what connects to R pin and a brown wire. an always hot pin. maybe this side of the circuit collapses under load?
maybe the problem is in the wire loom of this brown wire as it leaves the headlight switch harness and goes up under the steering column?
Maybe the problem is out under the hood with a connection somewhere?
I can perhaps take part of the dash apart and hand over hand this wire?
Dec 30, 2023 at 2:42 PM
