I installed a new bulb in it, and a new plug condenser. light is till dim. What else can I try?
Sep 24, 2022 at 6:26 AM
MIKE H R
CERTIFIED EXPERT
Check the wire that goes to the ground, have seen them get loose and corroded.
Mike
Sep 24, 2022 at 11:39 AM
ANDY BAEZ
MEMBER
Thanks'. l'll check the ground wire. and get back to you. Thank you Mike.
Sep 24, 2022 at 12:14 PM
ANDY BAEZ
MEMBER
Hi Mike, I was unable to find the ground wire in the wire harness. So, I ran a new ground wire to the black wire. And everything is working great. Thank you for your help. Andy
Sep 25, 2022 at 8:40 AM
MIKE H R
CERTIFIED EXPERT
Most grounds for the lights are near the light and make the ground connection to the body. Glad it worked out.
