I recently had my front passenger window smashed and found myself needing to replace it. I went to the local salvage yard and pulled one out of one of the same generation came up but without leather and with navigation. Went to install it after cleaning out all the broken glass from the window run and inside the door, etc., and it seems as if the window is slightly too wide? I can roll it about halfway up before it gets wedged in.
Are there different sized windows for different trim levels? Or is something else bent? Without the new window in, everything seemingly operates as it should.
Aug 13, 2022 at 7:13 PM
