Hello. I have the truck listed above K2500 4x4 6.5 turbo diesel. The truck runs perfectly when temperatures outside are 70 degrees and above. But as soon as it's below that the worse it runs and the colder it is even worse it runs. But as you drive it, it starts running smoother and then to normal. It also had a hard starting issue when it's cold out. But again, once it is 70 degrees it will fire no problem. Once it starts it idles perfectly and warms right up to temperature. I have put new glow plugs in it. Fuel pump and pressure is good throughout. Two new PMD with resistors. I just don't know why it runs perfectly in the summer and horrible in the winter. Thanks
Dec 9, 2023 at 6:07 PM
