Diesel replacement of the injectors?
2009 CHEVROLET CAPTIVA
140,000 MILES • 2.0L • 4 CYL • TURBO • 4WD • MANUAL
ABAYA
  • 77 POSTS
Is there any software programming to observe in the replacement of injectors?
Jan 3, 2024 at 11:27 AM
BORIS K
  • 836 POSTS
Once you have replaced the injectors on the 2.0 diesel engine you will need to program the injector (IMA) codes into the ECM using a suitable diagnostic tool.
The injector code is a 20-digit code located on top of the injectors but it should also be supplied on a separate information sheet
You will also have to reset the zero fuel correction (ZFC).
When installing new injectors do not reuse the washers and fuel supply pipes.
Fit new.
A video showing procedure:
https://youtu.be/rYkzkKHUDeQ?si=21YHt7nq0Nlw_sTH
Cheers, Boris
Jan 4, 2024 at 1:38 AM
ABAYA
  • 77 POSTS
Thank you very much.
Jan 4, 2024 at 2:38 AM
BORIS K
  • 836 POSTS
If you require any other information, please post your request here.
Always happy to help.
Cheers, Boris
Jan 5, 2024 at 12:42 AM
