It will turn over and start most the time and it will idle but when you rev it up it hesitates but stays running. If you turn the wheel and shift it into any gear but neutral it shuts off right away. No codes the last time I checked before this happen. It would lock and unlock randomly while driving then shut off while driving. I put a different battery in it it started up and I drove it home then it was doing the above problem.
Jul 17, 2018 at 4:19 PM
