Shuts off in second gear
2000 VOLKSWAGEN CABRIO
100,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
CHAZBONE69
  • 5 POSTS
Starts, idles and takes off in 1st gear shift to second shuts off.
Apr 2, 2020 at 8:00 AM
More than likely you have an issue with the spark plugs or coils. Have you removed the cover and inspected the coils? I suspect you have an oil leak causing a misfire. It may idle fine but once you introduce the load it stalls.
Let's start with pulling all the plugs and coils and look for oil.
Here is the process for the valve cover gasket as I suspect this is the ultimate issue.
Let me know what you find and we will see if we have proof to what I am thinking. Thanks
Apr 2, 2020 at 11:06 AM
CHAZBONE69
  • 5 POSTS
Coil changed still had the problem.
Apr 2, 2020 at 12:22 PM
CHAZBONE69
  • 5 POSTS
No oil on top part or front of motor.
Cleaned MAF sensor too. Pulls strong in 1st gear some other sensor maybe?
Apr 2, 2020 at 3:18 PM
Okay. Did you actually pull the plugs out and check them?
It could be a sensor but I would think more of something mechanical is happening because the engine doesn't really know the difference between first and second gear. Let me know if the plugs are good and we can go from there. Thanks
Apr 3, 2020 at 6:33 PM
CHAZBONE69
  • 5 POSTS
Plugs fine had crack in coil. replaced runs fine. thanks
Apr 4, 2020 at 6:26 PM
Wow. Not sure I would have thought of that. That is great info. Thanks for the update. Please come back to 2CarPros next time you need something. Thanks
Apr 4, 2020 at 6:42 PM
