Shuts off at idle?
1990 CHEVROLET 1500
202,915 MILES • 6 CYL • 2WD • AUTOMATIC
TXCHEVYGIRL1500
I'm having the same problem as many others with my truck shutting off at stop signs or lights after running for a bit. Now it doesn't want to turn over, just cranks. We've replaced the distributor cap and wires and plugs, fuel filter, fuel pump, ICM, o2 sensor, and I'm sure I'm missing something else. I'm thinking vacuum leaking but I'm far from a professional. What are your thoughts?
Oct 4, 2022 at 5:31 PM
Based on your description, it sounds like a faulty crankshaft position sensor. When they begin to fail, they are adversely affected by heat. Once it cools off, it will begin working again.
Here is what I need you to do: See if it starts for a couple of seconds using starting fluid. If it does and then stalls, then we know it's a fuel-related issue. If there is no change, we need to check for an ignition spark to the plugs.
Here is a link that explains how it's done:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Additionally, here is a link that explains the symptoms related to a failing sensor. Take a look through it and let me know if you feel it mirrors what you experience.
One last thought. You may want to consider checking to see if there are diagnostic trouble codes stored in the computer. This vehicle has an OBD1 system and doesn't require a scan tool to retrieve codes. All you need is a short jumper wire or even a paper clip.
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Let me know what you find.
Oct 4, 2022 at 8:13 PM
