Engine shuts off when slowing down, stopped or reversing
2010 PONTIAC G6
140,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
GUNGER
It runs great driving, but shuts off when stopping/stopped.
Jul 19, 2021 at 5:53 PM
SQM
  • 6,383 POSTS
Is your check engine light on? If so what are the codes?
This could point us to the right direction:
You could have a dirty mass air flow sensor or it could be a clogged EGR valve.
You might find these articles helpful:
https://www.2carpros.com/articles/how-a-mass-air-flow-sensor-works-maf
https://www.2carpros.com/articles/mass-air-flow-service
https://www.2carpros.com/articles/how-to-replace-a-mass-air-flow-sensor-maf
I have attached EGR and MAF replacement procedures for your reference.
Let me know of any questions.
Thank you.
Jul 19, 2021 at 6:38 PM
Good evening,
This could be a dirty throttle body from coking or carbon build-up on the throttle plate. I attached a guide below in cleaning the throttle body for you.
https://www.2carpros.com/articles/stall-at-idle
Another possibility is the EGR valve being stuck open from a piece of carbon.
I would remove the valve and look underneath and see if there is carbon holding the pindle partially open.
Jul 19, 2021 at 6:44 PM
