Shut off while driving will not start
1990 FORD BRONCO
129,000 MILES • 2.9L • 6 CYL • 4WD • MANUAL
88BRONC2
I replaced fuel pump and filter. Replaced coil and relays and fuses are good as well as inertia switch. Vehicle is a Bronco II.
Jul 7, 2019 at 12:55 PM
SCGRANTURISMO
  • 4,897 POSTS
Have you checked the engine oil level? Please check the engine oil level and the coolant level and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Jul 7, 2019 at 1:16 PM
88BRONC2
Yes all fluids are good.
Jul 7, 2019 at 1:41 PM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Okay, you need three things for an engine to start and run, 1) Spark (delivered at the proper time), 2) Fuel 3) Compression. If these three things are present then and engine has no choice but to start and run. So, let's see if your vehicle's engine is getting spark. Here is a link for you to go to below:
Please go through this guide and get to us and we will go from there.
Thanks,
Alex
2CarPros
Jul 7, 2019 at 3:27 PM
