Car not running right
2015 BMW 320I
81,000 MILES • 2.0L • 4 CYL • AUTOMATIC
MAITO242
Here is a video showing the issues I am having with my car:
http://aitus.golo365.com/Home/Report/reportDetail/diagnose_record_id/3831ac02kV3bAEAEOM54oG/report_type/E/timezone/01/l/en-us/golo_user_id/1582371&source=1
Jan 17, 2020 at 2:46 PM
Looks like you have multiple serious misfires which means the engine is probably running pretty poorly.
Let's start with doing a compression check and going from there.
Also, please let us know what has been done and what happened to cause this issue. Did the engine overheat?
Jan 18, 2020 at 9:43 AM
MAITO242
1. No over heating.
2. When it started I change the plugs a the adapters.
3. Used injection cleaner in the fuel tank .
4. But the problem goes off and on.
5. It displays driver mainstream malfunction.
Jan 18, 2020 at 11:52 AM
When this happens, what exactly is it doing? Does it run rough or stall? Maybe getting a video of the dash when this is happening will help figure this out.
Thanks
Jan 19, 2020 at 9:05 AM
