Transmission only has about 35,000 miles on it. When cold outside, it revs up and does not want to shift into second or third. It eventually does but clearly there is a problem. Sometimes down shift into first is delayed too. I replaced all three shift solenoids (A,B,C) but did not fix.
All I can find online is that it could be clutch pressure switches, TCU or I think i saw this valve down by the clutch pressure swtich-
https://shop.advanceautoparts.com/wcsstore/CVWEB/staticproductimage//424/large/10787482_wpc_j4006131506oes_pri_larg.jpg
Fluid looks great. Shift great when warmed up.
Is there a way to determine exactly what's causing this?
Dec 10, 2018 at 8:38 AM
