Delayed shifts only when cold
2001 HONDA ACCORD
175,000 MILES • 2.2L • 4 CYL • 2WD
ASTROCHIMP
Transmission only has about 35,000 miles on it. When cold outside, it revs up and does not want to shift into second or third. It eventually does but clearly there is a problem. Sometimes down shift into first is delayed too. I replaced all three shift solenoids (A,B,C) but did not fix.
All I can find online is that it could be clutch pressure switches, TCU or I think i saw this valve down by the clutch pressure swtich-
https://shop.advanceautoparts.com/wcsstore/CVWEB/staticproductimage//424/large/10787482_wpc_j4006131506oes_pri_larg.jpg
Fluid looks great. Shift great when warmed up.
Is there a way to determine exactly what's causing this?
Dec 10, 2018 at 8:38 AM
Good morning,
Good chance this is nothing more than the valve body not working smoothly when cold and the fluid is cold.
I would start by changing the fluid and adding a valve body modifier.
if it were electronic, you would have codes. Do you have any codes stored?
https://www.2carpros.com/articles/automatic-transmission-problems
Dec 10, 2018 at 9:08 AM
ASTROCHIMP
I will get the codes read very soon.
Thanks for those links!
Dec 11, 2018 at 4:53 AM
You are welcome.
Always glad to help.
Dec 11, 2018 at 6:43 AM
