Good morning.
I attached a wire diagram for you to view. Check the fuses with a test for power on both sides. There is a relay that needs power in order to let the blower motor work.
You can also check for voltage to the blower motor as well to see if the voltage is present which may indicate a bad blower motor.
The blower motor is under the right side of the dash.
Jun 22, 2021 at 11:33 AM
(Merged)
