Car blow heat from the vent but not from the floor board and defrost vent.
Jan 22, 2019 at 5:37 PM
CERTIFIED EXPERT
Good evening
The most common cause for this is the programmer for the AC. It is the box behind the glove box that has the rod coming out that moves the door for air flow.
Can you hear or see it moving when you command defrost and floor?
Jan 22, 2019 at 7:23 PM
NALLS
MEMBER
No,I see the actuator moving for heat and air. And also a black round part behind a door
Jan 22, 2019 at 7:29 PM
CERTIFIED EXPERT
OK, good chance the programmer is not commanding the door positions to change.
Jan 22, 2019 at 8:21 PM
NALLS
MEMBER
So the programmer is going bad. Will disconnecting the battery to reboot help?
Jan 22, 2019 at 8:25 PM
CERTIFIED EXPERT
No, there is no such thing as a reboot.
Removing the battery cable will have no effect on this issue.
Jan 22, 2019 at 8:32 PM
NALLS
MEMBER
So what is the name of the part I need to look for?
Jan 22, 2019 at 8:34 PM
CERTIFIED EXPERT
Ac programmer. I showed you the part from rock auto
Jan 22, 2019 at 8:37 PM
NALLS
MEMBER
My year doesn't call for a programmer. 91 cadillac brougham 5.7 engine
Jan 22, 2019 at 8:48 PM
NALLS
MEMBER
My bad found it
Jan 22, 2019 at 8:53 PM
CERTIFIED EXPERT
Yes, they changed that system in 93.
Jan 23, 2019 at 4:51 AM
NALLS
MEMBER
I also noticed I'm pulling a code 132 and 141
Jan 23, 2019 at 5:02 AM
CERTIFIED EXPERT
Where did you get those codes from?
Jan 23, 2019 at 5:04 AM
NALLS
MEMBER
From my ecc
Jan 23, 2019 at 5:05 AM
CERTIFIED EXPERT
Did they have a E or F in front of them?
Jan 23, 2019 at 5:22 AM
NALLS
MEMBER
Neither just numbes
Jan 23, 2019 at 5:52 AM
NALLS
MEMBER
Error I mean 140 and 132
Jan 23, 2019 at 5:54 AM
CERTIFIED EXPERT
They are not codes.
When you hold the off and warmer buttons at the same time, it will go into diagnostic mode.
The codes with start with the letter E and then numbers. When that is completed it will list F and then numbers.
When that is complete then it will display 7.0.
Jan 23, 2019 at 5:58 AM
NALLS
MEMBER
My car don't read out like that
Jan 23, 2019 at 6:13 AM
CERTIFIED EXPERT
Is this the control head in your car?
Image (Click to enlarge)
Jan 23, 2019 at 6:22 AM
NALLS
MEMBER
Sure is
Jan 23, 2019 at 6:29 AM
CERTIFIED EXPERT
OK, then follow the instructions I sent you and the on-screen picture I sent and take a screenshot of your results and upload it here for me to see.
Jan 23, 2019 at 6:32 AM
NALLS
MEMBER
Readings
Jan 23, 2019 at 10:20 AM
CERTIFIED EXPERT
They are not codes. Did they appear right after putting it into diagnostics?
This may be the programmer sending bad info. With the replacement, it should show the correct format.
Jan 23, 2019 at 10:23 AM
NALLS
MEMBER
Yes once I pressed both buttons it started showing these codes. So are you saying the programmer may solve this ?
