All electrical is not working
2012 BUICK VERANO
108,400 MILES • 4 CYL • 2WD • AUTOMATIC
KIMBERLY FALK
First my gear shift knob button fell apart. then next day my car is completely dead. haven't had any trouble with battery it is only 2 years old. Are these 2 things related in the car being completely dead?
Aug 22, 2019 at 4:17 PM
I don't see how these are related. The gear shift simply has the shift interlock in it and this will not cause the battery to drain.
The way to figure this out is to do what is called an ignition off draw test to find out what is draining the battery.
However you can first run through these common causes first.
https://www.2carpros.com/articles/car-battery-dead-overnight
If that does not show you the issue then you will need to do the draw test. Here is a video that shows how to do this:
https://youtu.be/KF1gijj03_0
Aug 22, 2019 at 5:36 PM
