dead battery on Nissan Rogue?
2013 NISSAN ROGUE
130,000 MILES • 4 CYL • 4WD • AUTOMATIC
TOM EARLS
I tried to start my second vehicle (Nissan Rogue) using cables. Hooked it up positive to positive. I started my good car, Then tried to start my 1997 Ford Ranger. It didn't start. As I tried again I heard the engine in my car slowing down until it stopped running.
So what I am trying to do now is restart the Rogue with.
Is a phone charger enough to recharge the battery?
Mar 7, 2026 at 2:38 PM
TOM EARLS
The caar in the first line should be my 1997 Ford Ranger.
Mar 7, 2026 at 2:42 PM
CARADIODOC
  • 34,306 POSTS
Cell phones typically run on 5.0 volts. Even if a small charger like that could develop 13 volts or more, it would take the better part of a week to charge a car battery.
If you simply tried cranking the truck engine a few times, that alone is not enough to discharge the battery in the running vehicle. Sounds like there is a problem in the Ranger that is loading down the battery.
Mar 7, 2026 at 2:46 PM
STEVE W.
  • 15,113 POSTS
If the Rogue was connected and it drew it down until the engine shut down I would say it needs attention, Jump starting another vehicle shouldn't be able to do that. Even a fully dead battery in the Ranger shouldn't do that. If you are sure the cables were connected properly then I would plan on at least a new battery for the Rogue as well as having the charging system tested as it should have been able to keep running. What does the Rogue do when you try to start it? Do the headlights come on at all? Have you ever had it start slowly or any issues like a charge light coming on?
Mar 7, 2026 at 4:29 PM
