Sunday,19,May,2024,14:10:43:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.1.0 (x64)
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: WVGZZZ5NZKW846776 License Plate: QPT87
Mileage: 70947km-44084mi Repair Order:
Chassis Type 5N-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 22 3C 42 44 4B 52 57 5F 65
6C 6D 82 A5 CF
VIN: WVGZZZ5NZKW846776 Mileage: 70947km-44084miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
52-Door Elect, Pass. -- Status: OK 0000
57-TV Tuner -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
65-Tire Pressure -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
82-Heads Up Display -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
CF-Lane Chge Asst 2 -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-DFGA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 KR HW: 04L 907 309 P
Component: R4 2.0l TDI H25 3919
Revision: B4H25---
Coding: 0125003203661D083000
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_ECM20TDI01104L906026KR 004003
ROD: EV_ECM20TDI01104L906026GP_004.rod
VCID: 040DD1D28F1B166FBD-8050
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0DL 300 012 N HW: 0GC 927 711 G
Component: GSG DQ500 H06 2110
Revision: 00H06V07
Coding: 0014
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDQ500021 001001
ROD: EV_TCMDQ500021_001_VW37.rod
VCID: 346D41129F3B66EF4D-8060
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 EF HW: 5Q0 614 517 BP
Component: ESC H35 0107
Revision: 00000000 Serial number: 63228000002802
Coding: 0AEE929A30240B72477E0707A2C94950490CD0E2E04592753862500852AA4A0B00402F641A1B13111435351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
ROD: EV_Brake1UDSContiMK100IPB_038.rod
VCID: 79F3B026F8D95B87DE-802C
Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 3Q0 959 435 L HW: 3Q0 959 435 L
Component: VWKESSYMQB 037 1204
Revision: 00037000 Serial number: 0501279728
Coding: 132C2C0723
ASAM Dataset: EV_KessyHellaMQBAB 004046
ROD: EV_KessyHellaMQBAB_004_VW37.rod
VCID: 438F12CECA95D157C4-8016
Sensor Controlled Power Rear Lid:
Subsystem 1 - Part No SW: 3G0 962 243 C HW: 3G0 962 243 C
Component: GEB.F.Heckoef H17 0906
Serial number: 11336561
Address 08: Auto HVAC (E87) Labels:| 3V0-907-044.clb
Part No SW: 5NA 907 044 N HW: 5NA 907 044 N
Component: AC Automat H35 4301
Revision: 20K10000 Serial number: 00000B01173930
Coding: 0012010410210000110510001010152A
ASAM Dataset: EV_ACClimaPrehVW37X 002023
ROD: EV_ACClimaPrehVW37X.rod
VCID: 4A913FEAEDBF001F07-801E
Relative humidity sensor in fresh air intake duct:
Rear Climatronic Operating And Display Unit:
Subsystem 2 - Part No SW: 3G0 907 049 E HW: 3G0 907 049 E
Component: E265KlimaHeck H02 0201
Serial number: 04031501850571
Coding: 000000
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 085 BS HW: 5Q0 937 085 BF
Component: BCM MQBAB MNA H38 0273
Serial number: 00001833400296
Coding: 000000000000000000000000000000000000000000000000000000000000
ASAM Dataset: EV_BCMMQB 019001
ROD: EV_BCMBOSCH_019_VW37.rod
VCID: 0B1FFAEEA2455917FC-805E
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 5NC 955 119 A HW: 5NC 955 119 A Labels: 1KX-955-119.CLB
Component: 326 RL 301118 033 0372
Serial number: 00000001811280301304
Coding: 0E4DDD
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 052 0107
Serial number: S5Y18M12D07H10M13S44
Coding: 01E8DD
Steering Column Switch:
Subsystem 3 - Part No SW: 5Q1 953 521 M HW: 5Q1 953 569
Component: Lenks.Modul H03 0170
Serial number: 0100021220180C102625
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 3Q0 919 298 E HW: 3Q0 919 298
Component: PLA 3.0 12K H09 0046
Serial number: 001910187498050
Coding: 0331767851
Shop #: WSC 19386 002 1048576
ASAM Dataset: EV_EPHBO2CVW3260000 010019
ROD: EV_EPHBO2CVW3260000.rod
VCID: 3F871E3EA67DB5B7A0-806A
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 Q HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0342
Coding: 320007D358FF8728749C810530408700000000000000000000
ASAM Dataset: EV_ACCMRRCONTIVW376 003015
ROD: EV_ACCMRRCONTIVW376_003_VW37.rod
VCID: 428117CAD58FD85FCF-8016
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 CA HW: 5Q0 959 655 CA
Component: AirbagVW21 006 0403
Serial number: 003FPR4SKLT0
Coding: 98FCC0C00C0000005C5400CF008800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 0103D8C69009034796-8054
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 A HW: 4M0 980 945 A
Component: BeltPretRevFL 106 1040
Serial number: 5NC857705C0334S01849
Coding: 80000D
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 A HW: 4M0 980 946 A
Component: BeltPretRevFR 106 1040
Serial number: 5NC857706C0332S01355
Coding: 80000D
Side Sensor Driver Front:
Subsystem 3 - Part No SW: ----------- HW: 480 000 312 18
Component: SideSensor_Df 001 0887
Serial number: 357000000005B750363C
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 4 - Part No SW: ----------- HW: 480 000 312 18
Component: SideSensor_Pf 001 0887
Serial number: 358000000007B750363F
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 5 - Part No SW: ----------- HW: 480 400 512 18
Component: SideSensor_Dr 004 6149
Serial number: 35100011E2B72252B3A.
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 6 - Part No SW: ----------- HW: 480 400 512 18
Component: SideSensor_Pr 004 6149
Serial number: 35200011E2B72252C45Z
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 7 - Part No SW: ----------- HW: 480 400 412 18
Component: FrontSensor_D 003 6149
Serial number: 3550001A32E1DC44C25A
Coding: 2D2D2D
Pedestrian Protection Driver:
Subsystem 8 - Part No SW: ----------- HW: 480 400 612 18
Component: PedP_Sensor_D 004 6149
Serial number: 2280001042B6E6C3F303
Coding: 2D2D2D
Pedestrian Protection Passenger:
Subsystem 9 - Part No SW: ----------- HW: 480 400 612 18
Component: PedP_Sensor_P 004 6149
Serial number: 2290001042B6E6C255A5
Coding: 2D2D2D
Pedestrian Protection Center:
Subsystem 10 - Part No SW: ----------- HW: 480 400 612 18
Component: PedP_Sensor_C 004 6149
Serial number: 2300001042B6E6C4334W
Coding: 2D2D2D
Pedestrian Protection Driver 2:
Subsystem 11 - Part No SW: ----------- HW: 480 002 611 18
Component: PedPSensor_D2 001 0887
Serial number: I0M00000000F9205463+
Coding: 2D2D2D
Pedestrian Protection Passenger 2:
Subsystem 12 - Part No SW: ----------- HW: 480 002 611 18
Component: PedPSensor_P2 001 0887
Serial number: I0N000000000A205463S
Coding: 2D2D2D
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5NA 920 790 D HW: 5NA 920 790 D
Component: KOMBI 506 1691
Coding: 24A400886E88000E0288630F1001000080000000
ASAM Dataset: EV_DashBoardVDDMQBA0 001026
ROD: EV_DashBoardVDDMQBA0_VW37.rod
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 442 4366
Revision: -------- Serial number: 0008820765
Coding: 0B0500045F087300FB07225E1E0F00010001070000000000000000000000
ASAM Dataset: EV_GatewNF 013025
ROD: EV_GatewNF.rod
VCID: 6ED9937AB1970C3F7B-803A
Alternator:
Component: 0-00-00-00-00
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 5G0 959 442 AE HW: 5G0 959 442 AE Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0052
Serial number: 29180002803540018475
Coding: 2DFFFF
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Component: J367-BDMHella H10 9070
Serial number: 3062869604
Power Converter DC AC:
Subsystem 4 - Part No SW: 5Q0 907 155 G HW: 5Q0 907 155 G
Component: U13DCAC H27 0810
Serial number: 9302821
1 Fault Found:
66304 - Databus
U1124 00 [009] - Additional Installations Detected
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 108
Mileage: 70947 km
Date: 2024.05.19
Time: 14:04:37
Supply voltage: Terminal 30: 11.7 V
Terminal 15: On
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H55 7084
Serial number: HA1-00009.11.18
Coding: 0101
ASAM Dataset: EV_AllWheelContrHA1VW37X 004013
ROD: EV_AllWheelContrHA1VW37X_004.rod
VCID: 4C9D39F2E7CB1E2F35-8018
Address 3C: Lane Change (J769) Labels:| 3Q0-907-566.clb
Part No SW: 3Q0 907 566 G HW: 3Q0 907 566
Component: MRR1Rear H23 0530
Revision: --------
Coding: 44C002
ASAM Dataset: EV_RearRadarS1BoschVW48X 001007
ROD: EV_RearRadarS1BoschVW48X.rod
VCID: 3C7D6932B76BAEAF85-8068
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 F HW: 5Q0 959 593 F
Component: TSG FS001 0287
Serial number: YE007RKN3142D
Coding: 003F1B20D001048000001000
ASAM Dataset: EV_DCU2DriveSideMAXHKLO 001010
ROD: EV_DCU2DriveSideMAXHCONT_VW37.rod
VCID: 448D11D2CF9BD66FFD-8010
Drivers Door Rear Control Module:
Subsystem 1 - Part No SW: 5Q0 959 812 E HW: 5Q0 959 812 E
Component: FOND_FHSG_DRV 006 0007
Serial number: 00000000000025678560
Coding: 0D0000
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 AB HW: 5Q0 909 144 AA
Component: EPS_MQB_ZFLS 130 1082
Coding: 93170000
ASAM Dataset: EV_SteerAssisMQB 015157
ROD: EV_SteerAssisMQB_015.rod
VCID: 74ED8112DFBB26EF8D-8020
Address 4B: Multifunc. Module
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 F HW: 5Q0 959 592 F
Component: TSG BFS001 0287
Serial number: YE007RKO2022A
Coding: 003F1120DC01048000001000
ASAM Dataset: EV_DCU2PasseSideMAXHKLO 001010
ROD: EV_DCU2PasseSideMAXHCONT_VW37.rod
Passengers Rear Door Control Module:
Subsystem 1 - Part No SW: 5Q0 959 811 E HW: 5Q0 959 811 E
Component: FOND_FHSG_PSG 006 0007
Serial number: 00000000000023397466
Coding: 050000
Address 57: TV Tuner (R78) Labels:* None
Part No SW: 8V0 919 129 F HW: 8V0 919 129 D
Component: JP-DTV H12 2110
Coding: 02041C0000000100000002
ASAM Dataset: EV_TVMELC 001039
ROD: EV_TVMELC_VW37.rod
1 Fault Found:
1570 - Internal Control Module Memory Check Sum Error
B2000 46 [009] - Calibration/parameter memory failure
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Mileage: 70602 km
Date: 2024.04.24
Time: 04:46:01
Voltage terminal 30: 13.1 V
Address 5F: Information Electr. (J794) Labels:* None
Part No SW: 5NA 035 050 D HW: 5NA 035 050
Component: MU-H-N-JP 055 1101
Serial number: K5F AW7ZF17PBZ
Coding: 02730606FF00000051380001001038001F0106E601200400FE
ASAM Dataset: EV_MUHig4CGen2AW7 001081
ROD: EV_MUHig4CGen2AW7_VW37.rod
VCID: 356B7C1694417FE77A-8060
Operating And Display Unit 1:
Subsystem 1 - Part No SW: 5G6 919 606 HW: 5G6 919 606
Component: ABT_High-2 H52 9130
Serial number: VWZ6ZJV3411495
Data medium:
Subsystem 2 - Part No SW: V03 959 801 BR HW: -----------
Component: JPN 2018/2019 --- 8011
Serial number: --------------------
Chip Card Reader Control Module:
Subsystem 3 - Part No SW: 4K0 919 813 HW: 4K0 919 813
Component: ETC2.0 UNIT H03 0002
Serial number: 547148133400
Traffic Data Aerial:
Subsystem 4 - Part No SW: 8V0 035 504 C HW: 8V0 035 504 C
Component: VICS Antenna H08 0002
Serial number: 551110002501
Compact Disc Database:
Subsystem 5 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 2017
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 5Q0 907 273 C HW: 5Q0 907 273 A
Component: RDKBERU30 H04 0009
Serial number: 40000000007434
ASAM Dataset: EV_RDKBERU30 006001
ROD: EV_RDKBERU30_006_VW37.rod
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 5Q0 907 556 C HW: 5Q0 907 556
Component: Areaview 2 H13 0608
Serial number: C854707JG042532
Coding: 01230606A20F200000204094
ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
ROD: EV_CamSysRVAV2ARCE2MQBAB.rod
VCID: 39737026B8599B879E-806C
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 5Q0 959 107 Q HW: 5Q0 959 107 C
Component: HDSG-Modul H12 0266
Revision: -------- Serial number: 32229916300000
Coding: 0A28
ASAM Dataset: EV_DeckLidCONTIAU736 001016
ROD: EV_DeckLidCONTIAU736_VW37.rod
VCID: 46890BDAF9A7E47FE3-8012
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 5NA 919 608 B HW: 5NA 919 608 B
Component: HeadupDisplay 023 0302
Coding: 564060
ASAM Dataset: EV_HeadUpDisplContiVW481 001015
ROD: EV_HeadUpDisplContiVW481.rod
VCID: 479706DEFEADFD7718-8012
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H09 0272
Serial number: 22081815K12288
Coding: 000307060000050100022346C140A90084000E200040
ASAM Dataset: EV_MFKBoschMQBB 001001
ROD: EV_MFKBoschMQBB_001_VW36.rod
Address CF: Lane Chge Asst 2
End-------------------------(Elapsed Time: 05:26)--------------------------
May 18, 2024 at 8:22 PM
