There is a chance that a fuse has failed. Do me a favor. I looked through the wiring schematics and noted that power for the items you mentioned originates at fuse 36 (ign B) fuse in the under-hood fuse box. I need you to locate the fuse and check to see if it is good. In addition to checking the fuse, I need you to confirm there is power to and from it.
Additionally, if you look below, I attached a pic of the under-hood fuse box and highlighted the fuse to check.
See pic below.
Mar 7, 2022 at 7:23 PM
