Welcome to 2CarPros.
I'm not sure how the two would be related. As far as the code, it is for a lean fuel mixture. Most times, it is caused by an engine vacuum leak, an exhaust leak, or a weak fuel pump. With that code, the catalytic converter is most likely fine.
Lets start with the code issue. First, are there any exhaust leaks? If not, then follow this link to check for engine vacuum leaks.
If none are found, then check fuel pressure.
Here are the directions specific to your vehicle for testing fuel pressure. The attached pictures correlate with the directions, and the manufacturer's specs are included. Also, the directions include a flow chart if you find the pressure is low. However, they will require a scan tool to complete.
___________________________
FUEL DELIVERY CHECK
*CHECKING THE FUEL DELIVERY SYSTEM
pic 1
For a complete wiring diagram refer to Diagrams/Electrical.
pic 1
Diagnostic Test
1. FUEL PUMP OPERATION
Ignition on, engine not running.
With a scan tool, actuate the Fuel System test.
NOTE: It may be necessary to use a mechanics stethoscope in the next step.
Listen for fuel pump operation at the fuel tank.
Does the Fuel Pump operate?
Yes
- Go To 2
No
- Go To 5
CAUTION: Stop All Actuations.
2. FUEL PRESSURE
WARNING: The fuel system is under a constant pressure (even with the engine off). Before testing or servicing any fuel system hose, fitting or line, the fuel system pressure must be released. Failure to follow these instructions can result in personal injury or death.
Turn the ignition off.
Install a fuel pressure gauge at the engine.
With the scan tool, actuate the ASD Fuel System test and observe the fuel pressure gauge.
NOTE: Fuel pressure specification is 407 KPa ± 34 KPa (59 psi ± 5 psi).
Choose a conclusion that best matches your fuel pressure reading.
Below Specification
- Go To 3
Within Specification
- Test Complete.
Above Specification
- Replace the fuel filter/fuel pressure regulator.
- Perform the POWERTRAIN VERIFICATION TEST. See: A L L Diagnostic Trouble Codes ( DTC ) > Verification Tests > Powertrain Verification Test
3. RESTRICTED FUEL SUPPLY LINE
WARNING: The fuel system is under a constant pressure even with the engine off. Before testing or servicing any fuel system hose, fitting or line, the fuel system pressure must be released.
Raise vehicle on hoist, and disconnect the fuel pressure line at the fuel pump module.
Install special tool #6539 (5/16 inch) or #6631 (3/8 inch)
fuel line adapter and the fuel pressure gauge between the fuel supply line and the fuel pump module.
Is the fuel pressure within specification now?
Yes
- Repair/replace fuel supply line as necessary.
No
- Go To 4
4. CHECKING FUEL INLET STRAINER
Remove the Fuel Pump Module and inspect the Fuel Inlet Strainer.
Is the Fuel Inlet Strainer plugged?
Yes
- Replace the Fuel Pump Inlet Strainer.
No
- Replace the Fuel Pump Module.
5. (A109) FUEL PUMP RELAY OUTPUT CIRCUIT OPEN
Remove the Fuel Pump Relay from the IPM.
Disconnect the Fuel Pump Module harness connector.
Measure the resistance of the (A109) Fuel Pump Relay Output circuit from the relay connector to the fuel pump module connector.
Is the resistance below 5.0 ohms?
Yes
- Replace the Fuel Pump Relay.
No
- Repair the open in the (A109) Fuel Pump Relay Output circuit.
I hate to ask this, but I need you to copy and paste the electrical question to a new thread. We are trying to keep the answers specific to one problem as to better help others.
Let me know what you find.
Apr 30, 2019 at 8:04 PM
