Dashboard light not coming up with headlamp on
2004 TOYOTA COROLLA
235,675 MILES • 4 CYL • 2WD • AUTOMATIC
BLESSING EWOBOR
  • 754 POSTS
Hello, the vehicle's dashboard light is not coming on with the head light on. The radio too has refused to power. I have checked all the fuses they are in good condition. What could have been the cause?
Mar 11, 2021 at 1:31 PM
I-SMOGEM
  • 118 POSTS
Has anyone else driven it lately?? As far as the dash lights, have you checked the dash dimmer switch (if you have one)? Someone may have moved it.
As far as the fuses go, did you check both the under hood and under dash boxes with a test light or volt meter? Is anything else not working?
I know I'm hitting you with questions, but I see no immediate commonality with the two systems. A common item in many vehicles is the cigarette lighter/power outlet circuit that is also involved with other electrical systems. Please see if it is working.
Other techs may jump in if they have other info or have come across this before.
Glenn
Mar 11, 2021 at 4:37 PM
BLESSING EWOBOR
  • 754 POSTS
Yes, I checked the both the under hood and under dash with test light. Could I have a circuit diagram for this?
Mar 11, 2021 at 7:57 PM
BLESSING EWOBOR
  • 754 POSTS
The cigarette lighter is working.
Mar 11, 2021 at 7:59 PM
I noticed it's been a couple of days since you were here. As far as the wiring schematics, I attached them below. I cut it in half to make it readable.
Let me know if that is what you needed. It is for the instrument panel/lights.
Mar 13, 2021 at 8:30 PM
BLESSING EWOBOR
  • 754 POSTS
Thank you very much.
Mar 14, 2021 at 4:33 AM
You're very welcome. Let us know if you have other questions.
Mar 15, 2021 at 5:55 PM
