Hi, a couple of months ago my car's ABS motor started running continuously, even when the engine was off. This caused the battery to die many times, so we used to disconnect the negative battery cable when the car was parked. Later, I removed the ABS motor fuse, which solved the battery problem, but now the brake warning light doesn't turn off and the odometer/kilometer readings are not working. PS: The dynamo pulley ball bearing was broken. I fixed it yesterday.
Sep 27, 2025 at 9:31 AM
