Former U-Haul truck, based on E450 van.
Everything seemed to be fine except the radio display was screwed up, so I wanted to replace the radio. I pulled out the radio and cut the wires (15 of them) that were coming out of the hole. I also unplugged the antenna from the old radio. I tried to wire up the new radio and couldn't get it to turn on at all, tried reconnecting all the wires as they were, and the old radio didn't work either. Also, the dashboard gauges and dome light stopped working. I found only one blown fuse, the radio fuse. After replacing it, I tried wired both radios again and still neither works and no life from gages or dome light. I found voltage from some of the wires coming out of the radio hole using a multimeter, and the radio fuse blows again if I mash together the wires. But at no point is there any sign of life in the old radio, new radio, or gauges.
Any ideas?
Any ideas?
Dec 27, 2021 at 10:01 AM
