Vehicle sat for approximately 10 months. Battery died. Removed battery and charged fully. Upon start up, engine missed at 1,000 rpm's. Dash voltmeter was/is unresponsive. Digital odometer goes out (no flicker or change in intensity) at approximately same time engine miss starts.
No check engine light ever displays.
Chasing miss resulted in new plugs, coil rail, fuel injectors. Verified all injector signals with noid light. Miss remained.
Battery voltage is 12.4, not started. However, running battery voltage increases to 17.1 as rpm increases. At that voltage, miss starts and digital odometer goes out.
Dash volt meter responds to cluster self-test.
I’ve verified all the grounds I can find.
Scan tool shows no numbered codes, but does indicate a control module internal fault.
Is this possibly an internal voltage regulator failure?
Oct 3, 2019 at 5:02 PM
