First, there are two fuses involved. One is the signal and the other is the hazard. I have a feeling the signal may be blown. Also, there is a ground under the dash, at the center, which will affect all the things you mentioned. I need you to check that as well
If you look at the attached pics below, they include the entire wiring schematic for the exterior lighting. In pic 1, I circled the fuses and highlighted the ground I need to be tested.
When testing the fuses, conform there is power to and from them. Here is a link you may find helpful:
Also, pic 5 shows the locations of the fuses.
If the fuses are good, confirm the black wire under the dash to ground is properly fixed and tight.
See pics below.
Apr 13, 2021 at 8:19 PM
