Dash light for speedometer not working
2005 FORD RANGER
189,000 MILES • 4.0L • 6 CYL • 4WD • MANUAL
JDSTEPHENS
The dash light for the speedometer isnt working. The other lights in the insturment cluster work as does the dimmer switch. I replaces fuses 1 and 33 to get the lights working and the speedometer lights still aren't working. Any suggestions?
Feb 23, 2019 at 9:34 AM
SCGRANTURISMO
  • 4,897 POSTS
This could be just a burnt out bulb in the odometer. I have included step by step directions for replacing any burnt out instrument cluster bulbs in the diagrams below. I hope this helps.
Thanks,
Alex
2CarPros
Feb 24, 2019 at 7:48 AM
JDSTEPHENS
I’ve changed all of the lights in the instrument cluster. The only ones that don’t work are the three that illuminate the speedometer. Could it be that these bulbs aren’t getting power from the plug on that side of the cluster? If so can you tell me which wire in that plug feeds power to those lights?
Thanks
Feb 24, 2019 at 8:49 AM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
The information you requested is in the diagrams down below.
Thanks,
Alex
2CarPros
Feb 24, 2019 at 5:31 PM
JDSTEPHENS
Do you have a more detailed schematic of the instrument cluster?
Feb 24, 2019 at 5:48 PM
SCGRANTURISMO
  • 4,897 POSTS
Unfortunately, we do not have a detailed schematic. Usually if there is a problem with the instrument cluster, it is replaced as a single item. We don't get into the circuit boards of components that way.
Thanks,
Alex
2CarPros
Feb 25, 2019 at 3:40 AM
