dash lights and gauges go out but sometimes come back on?
2013 DODGE CARAVAN
80,000 MILES
DODGE PERSON
MEMBER
FOLLOW
The dash lights and gauges go out but sometimes come back on. I replaced instrument cluster and TIPM, do you have any idea what could be going on?
May 4, 2023 at 4:45 PM
CERTIFIED EXPERT
This sounds like the dimmer switch is going out here is the instrument cluster lighting wiring diagrams so you can see how the system works and I have included how to change the dimmer switch out as well. Check out the images (below). Please let us know what happens.
May 5, 2023 at 9:30 AM
DODGE PERSON
MEMBER
Is this diagram for a 2013 Dodge caravan? Also, I forgot to mention wipers come on gauges don't work, turn signals won't work, and dash doesn't light up. what could be happening?
May 5, 2023 at 6:39 PM
CERTIFIED EXPERT
Yes, the diagrams are for a 2013 Dodge caravan. It sounds like you have a defective TIPM, but to be sure let's do a CAN scan. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
