I have seen the cluster go out and cause this, but we should check the fuses first. This guide can help, and I have included the fuse location in the images below for clarification. Please check the fuses with the key on.
If the fuses are good, you should do a CAN scan which will help you by showing the codes.
You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Here is how to change out the cluster, you can get a preprogrammed unit by searching Google or Ebay. Check out the images (below). Please let us know what happens.
Nov 5, 2023 at 12:05 PM
