Traction control fault light turned on
2010 MITSUBISHI DELICA
111,543 MILES • 4 CYL • 4WD • AUTOMATIC
ANNIE PROCTOR
traction control fault light is coming up on the dashboard.
Jan 1, 2021 at 10:47 PM
This could be a couple things but most likely a wheel speed sensor issue. However, we need to scan for codes to find out what the possible causes are. Here is a guide that will help with this:
Once we know what the codes are we will have a better idea.
However, here is a guide that will help with the speed sensor testing if this proves out to be the issue. However, we need the codes first. Thanks
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Jan 3, 2021 at 3:56 PM
