Bought this car just recently, the brake light in the dash is on. I have replaced rotors and pads, also replaced the master cylinder (it apparently was leaking between brake booster, paint was eaten away). I saw another similar issue you answered to. My car does not have a master cylinder sensor. I did unplug the single wire plug that is on the silver block that the two lines run to out of the master cylinder and the light goes off. Is the plug a sensor? Can that be changed out? Plugged back in and the lights back on.is that plug replaceable, looks as if it might thread in. Or could it be a faulty emergency brake sensor in the console area?
Sep 5, 2022 at 11:52 AM
