2003 Daihatsu Sirion Vibration
2003 DAIHATSU SIRION
67,000 MILES • 4 CYL • 2WD • AUTOMATIC
S_ALLWYN
Recently my car has been vibrating when i drive in the reverse mode, today it happended in drive mode and started vibrating on a greater speed and stopped, it starts but vibrates even in nutral mode. if i dont race the engine then the car runs for a few seconds and stops, please advice what can be the problem. I was also told by the car dealer few months back one of the engine mount needs to be changed and was unable to do so because the part was not available.
Aug 17, 2010 at 8:11 AM
KHLOW2008
  • 41,814 POSTS
Hi s_allwyn,
Symptoms concur with what the dealer says, at least one of the engine mount is bad and quite often when one goes, the others would not be far behind.
Be prepared to replace more than one if not all of them.
Aug 17, 2010 at 8:46 AM
