Engine Mechanical problem
1993 Daihatsu Charade 4 cyl Front Wheel Drive Automatic
I am working on a 1300cc Charade, which I've rebuilt the head, & replaced a piston, because of nut being dropped down the plug tube. The engine now purrs like a kitten, untill an intermittent rattle starts in the top of the engine. I have reset the tappets & checked the timing. Plugs are very light grey. Sound may last a couple of seconds to half a minute, then stops. You can rev the engine & it runs great. Then the knock comes back, & sometimes the engine will even stall at idle. Would greatly appreciate any advice & help. Thanks.
Jun 6, 2008 at 8:55 PM
