1987 Daihatsu Charade GTti Idling problem
1987 DAIHATSU CHARADE
KEF
Engine Performance problem
1987 Daihatsu Charade Front Wheel Drive Manual
Dear Sir,
I having problem with my car idling. When i have my air-con switch off, the idling run very rough, jumping up and down rapidly between 950-1050rpm. When the air-con is switch on, everything went fine. Is there anything wrong? Thanks.
Cheers,
Kef
Apr 28, 2008 at 7:00 AM
Check your idle speed controller
Apr 28, 2008 at 7:16 AM
KEF
Hi rasmataz, thanks for your reply. I 'd tried lowering the idling by unscrewing on the idle spped controller but this time when I on the air-con, idling start to jump between 500-950, at a slower speed though. Its like either I down the idle speed to keep idling stable( without aircon on) or i up the idling to keep it stable(with aircon on).
Apr 29, 2008 at 8:29 PM
