2001 Daewoo Nubira Cam shaft position sensor
2001 DAEWOO NUBIRA
119,198 MILES • 4 CYL • FWD • AUTOMATIC
EVELIO CRUZ
I can't pass state inspection. I was told by Lambs Automotive that I need to replace the cam shaft position sensor, and the thermostat.
Please, is this true? And where is the cam shaft position sensor.
Aug 26, 2009 at 10:57 AM
UBOI
mine was the same..obd2 code P0341 and P0342 from the check engine light...sensor should be under valve cover...open valve cover and belt cover....
Jan 19, 2010 at 8:42 PM
