Recently the lock for the transmission has started to malfunction and will not always unlock the shifter from Park, and when this occurs the radio shuts off. However when the radio turns back on, the transmission can then be shifted out of park again. Both the radio fuses and the ECM fuses have been replaced and the transmission fluid has been topped off. Is this an issue with the transmission, or should I be looking for something else? Also it does not matter what the weather is outside when this happens. Please help.
Oct 14, 2009 at 9:35 AM
