2000 Daewoo Nubira Nubira High idles speed - where is the s
2000 DAEWOO NUBIRA
73,000 MILES • 4 CYL • 2WD • AUTOMATIC
SMGREEN
Hello
Having just aquired a Nubira CDX estate 2 litre automatic I have found that the idle speed is around 1450 rpm.
The previous owner stated that it had been like that since she had it (about 10 months)
Reading this forum, I suspect that the stepper motor may be at fault OR there is some kind on air leak.
Can someone please tell me where the stepper motor is located within the engine and how I might diagnose a possible fault before replacing it.
Thanks
Jul 28, 2008 at 7:04 AM
2CARPRO JACK
  • 11,533 POSTS
Spray around with carb cleaner first before buying the IAC, might be a vacuum leak.Here is a pic, it is located on the throttle body
https://www.2carpros.com/forum/automotive_pictures/1639_Daewoo_1.jpg
Jul 28, 2008 at 7:33 AM
SMGREEN
Thank you for your very speedy response - really appreciated
I'll get to work now and see how it goes
Regards
Jul 28, 2008 at 7:38 AM
