2000 Daewoo Nubira
2000 DAEWOO NUBIRA
LBTRUSTING
2000 Daewoo Nubira 4 cyl
WHERE IS THE KNOCKING SENSOR LOCATED AND HOW DO I CHANG IT?
Sep 29, 2009 at 10:21 PM
DAVE H
  • 13,384 POSTS
Disconnect negative battery cable. Remove intake manifold. Disconnect electrical connector at Knock Sensor (KS) Remove (KS).
Install KS. Tighten knock sensor bolt to 15 ft. lbs. (20 N.m). Connect electrical connector at KS. Install intake manifold. Connect negative battery cable.
Apr 11, 2010 at 6:55 AM
