1999 Daewoo Nubira timing belt
1999 DAEWOO NUBIRA
150,335 MILES • 4 CYL • 2WD • AUTOMATIC
REEPER
hi just put a new timig belt o my 1999 daewoo ubira and its timed right and i have spark and ful but wont start?
Dec 9, 2008 at 3:58 PM
ZACKMAN
  • 4,202 POSTS
Make sure your crankshaft sensor is installed right (not backward) and is plugged in.
Dec 9, 2008 at 7:44 PM
REEPER
where would i find the crankshaft sensor ?
Dec 10, 2008 at 11:30 AM
ZACKMAN
  • 4,202 POSTS
CRANKSHAFT POSITION SENSOR Removal 1. Disconnect negative battery cable. Remove power steering pump, if equipped. Remove A/C compressor, if equipped. Remove rear A/C compressor mounting bracket bolts and rear A/C compressor mounting bracket. See Fig. 34 . 2. Remove accessory mounting bracket by removing bolts. Disconnect Crankshaft Position (CKP) sensor connector from fuel injector channel cover. Remove CKP sensor retaining bolt. Gently rotate and remove CKP sensor from engine block. Installation 1. Insert CKP sensor into engine block. Install CKP sensor retaining bolt. Tighten crankshaft position sensor retaining bolt to 58 INCH Lbs. (6.5 N.m). Connect CKP sensor connector to fuel injector channel cover. Install accessory mounting bracket. Tighten accessory mounting bracket bolts to 26 ft. lbs. (35 N.m). 2. Install rear A/C mounting bracket, if equipped. Tighten rear A/C mounting bracket bolts to 26 ft. lbs. (35 N.m). Install A/C compressor, if equipped. Install power steering pump if equipped. Connect negative battery cable.
https://www.2carpros.com/forum/automotive_pictures/55316_nubirackps_1.jpg
CAMSHAFT POSITION SENSOR Removal & Installation 1. Disconnect negative battery cable. Remove engine cover. Disconnect sensor electrical connector. Remove timing belt front cover. Remove camshaft position sensor bolts. Remove camshaft position sensor from top. 2. Install camshaft position sensor and bolts. Tighten camshaft position sensor bolts to 62 INCH Lbs. (7 N.m). Install timing belt front cover, crankshaft pulley, accessory drive belt, and air filter. Connect sensor electrical connector. Install engine cover. Connect negative battery cable.
https://www.2carpros.com/forum/automotive_pictures/55316_nubiracmps_1.jpg
Dec 10, 2008 at 9:52 PM
