2000 Daewoo Leganza head gasket
2000 DAEWOO LEGANZA
SPIKE00
Engine Mechanical problem
2000 Daewoo Leganza 6 cyl Two Wheel Drive Manual 73k miles
hiya there, im a mechamnic from northampton, england. i have a daewoo leganza with a blown headgasket but am very unsure on how to go about fixing it. it is the model which runs on a DOHC vauhall vectra engine but i am stuck with what i need to remove to get to the gasket.
if you could help??
many thanks
spike..
Apr 23, 2008 at 9:10 AM
BOBBYTECH1
  • 49 POSTS
hey!! ur leganza timing belt anapped!!! so it means that ur head is also damaged!!! what u need to do is to remove the head and send it to the machine shop because mostly all the valves in the head are bent now..
and the reason of ur timing belt to break is the rollerguides which are called idlers run with the timing belt and the bearings in them go before its timee!!!
i hope i helped u somwhat!!
Jun 23, 2008 at 8:06 PM
