Cam Sensor
The Cam sensor is between the two cams at the top of the motor. If you remove the top cover (to see the spark plugs) you will see the wire going down to it on the left side of the motor. To replace it the right way,, you have to remove everything as if you were replace a timing belt. It's almost impossible to get to it thru the little opening where the motor mount is. You’ll first have to remove the air cleaner, top motor mount, remove the drive belt, and then remove timing cover. At this point you’ll be able to see the sensor between the two cams. You shouldn't have any problem replace it. Keep in mind, now that you have the front cover off, you might want to replace the timing belt and water pump while your're at it. Just an idea.. Good luck!!
Robert
Oct 7, 2008 at 10:29 AM
