2000 Daewoo Leganza Automobile Going Into Gear
2000 DAEWOO LEGANZA
16,800 MILES • 4 CYL • FWD • AUTOMATIC
MSTRICIA
What possible problems would cause the automobile not to shift gears. The transmission fluid and filter has been changed. Do you have any suggestions of things to try from here?
Thanks,
Tricia
Sep 9, 2010 at 7:55 PM
A.RINGHISER
  • 30 POSTS
if you cannot get your car to move, i think the following quote might help you to troubleshoot (at least for a slipping transmission) Thanks!
"Posted at Fri Sep 10, 2010 8:49 am
By rasmataz, Certified 2CarPros Master Technician
(26388) Give Feedback | Votes: 547
Sounds like your transmission is slipping bad-if not check the throttle position and manifold absolute pressure sensors-
_________________
Donations/Feedbacks/Votes are very much appreciated, Thank you for using 2carpros and please! do come back and invite friends/families to join-Goodbye and Take care"
Sep 11, 2010 at 12:25 AM
