Electrical problem
2000 Daewoo Leganza 4 cyl Two Wheel Drive Automatic
Question:
No Spark, I changed timing belt & head rebuilt.
Now No spark. I've replaced coil pack, ECM Computer,traced feed wires & GROUND. I have a OBD II scanner and shows no fault codes. Here is the kicker
<<<>>> at IGNITION.
(no Check engine light at all) Manual says if fuse, feed wires and ground are good than must be ECM. Replaced ECM (salvaged yard) 2x still no mill Light at ignition. I have spark tester.
If cam/crank sensors are bad wouldn't the MIL light still come on at ignition turn.
I hate to take the time to replace crank sensor when it may be Something else I'm missing.
I just am lost with this.
...?. .... Thanks Ken
Question:
Oct 31, 2008 at 10:16 AM
