1999 Daewoo Leganza Just doesn't stop good
1999 DAEWOO LEGANZA
90,000 MILES • 4 CYL • FWD • AUTOMATIC
YOBOBYO
  • 17 POSTS
I've replaced the shoes and turned the rotors, bled the brakes. The only thing was I might of let the master run low on fluid. But I've filled it, and bled all the old fluid out. As of now, I might have 30% to 40% of the brake power this car once had. I don't want to keep replacing parts. I've also replaced the master, and booster with no change. The pedal is soft but doesn't go to the floor. In the manual, it states something about if the ABS system were to get an air bubble you have to have the dealer bleed the air out with there ABS scanner. Is this true? or is there another way to do it.
Oct 6, 2008 at 7:18 PM
MERLIN2021
  • 17,250 POSTS
In normal procedures requiring removal of modulator, such as to replace EBCM, air will not enter modulator, and normal bleeding will be all that is needed. If air enters hydraulic modulator, or if an unfilled modulator is installed, use brake bleeding program in scan tool to bleed modulator. Manual bleeding of hydraulic modulator is not possible. In your case if the master ran dry while bleeding, the scantool is needed to bleed it!
Oct 7, 2008 at 5:25 PM
YOBOBYO
  • 17 POSTS
I understand what the manual said. I read it too. I was hoping to find out if there was any other way to bleed these brakes with out it. Or tell me just what does the scan tool does to bleed the brakes?? I don't understand how this tool bleeds the brakes.
Thanks for the answer to the first question. I'd give another 5.00 for the anwser to these question.
Thanks Robert
Oct 7, 2008 at 11:28 PM
MERLIN2021
  • 17,250 POSTS
The tool commands the unit to open pathways inside to allow bleeding, and I havent heard of any way to bleed them without doing this.
Oct 8, 2008 at 1:55 PM
YOBOBYO
  • 17 POSTS
Thanks for the info, and I would like to give another 5.00. But first, being that this is the first time doing this. How does the point system work??? and if I give another 5,, does it go to you for answering the question??
Let me know,, and I'll get that out to you..
Thanks again for the help.
Robert
Oct 8, 2008 at 2:18 PM
MERLIN2021
  • 17,250 POSTS
Give points by clicking the feedback link next to my name, some money goes to me and some to the owners of the shop, a fair arrangement, I appreciate your sentiment!
Oct 8, 2008 at 2:28 PM
YOBOBYO
  • 17 POSTS
When installing the brake pads. Does the pad with the sqweeler, go in front (outside) or to the back? (inside) It seems to fit both ways. I've alway put them to the front. but I thought I would ask and make sure.
and again,, how do you rate someone.. as far as points? and what it the scale you use??? Let me know,,, Thank you,,
Robert
Oct 19, 2008 at 9:15 AM
