2002 Daewoo Lanos air distribution
2002 DAEWOO LANOS
48,000 MILES • 4 CYL • FWD • AUTOMATIC
KEZZA SMITH
The air from the vents only blows on your face...not feet...windscreen etc. The air distribution switch turns but nothing happens. If this isnt the problem I was told to check the air hoses under the bonnet usually on the firewall. What do these look like & where might they be? I was told that maybe one has come off & needs putting back... I have been trying to find a diagram...so I can understand how it works...& if it is the switch how to take it off to replace it. Thankyou for any help Kezza
Jun 18, 2008 at 9:06 AM
BOBBYTECH1
  • 49 POSTS
hey!! I know what is wrong with ur car my friend, It is a mode cable which is directly connected to the mobe knob behind the panel. mode cable cost 10 dollars only. but u will hav problem getting the part because its only available where i work in toronto, if u need it call me at work 905 795 1647 days bobby.
Jun 23, 2008 at 7:36 PM
KEZZA SMITH
[quote:37300618e7="bobbytech1"]hey!! I know what is wrong with ur car my friend, It is a mode cable which is directly connected to the mobe knob behind the panel. mode cable cost 10 dollars only. but u will hav problem getting the part because its only available where i work in toronto, if u need it call me at work 905 795 1647 days bobby.[/quote:37300618e7]
Thanks Bobby...for the info...problem is I live on the Gold Coast...Qld...Australia...have a daewoo wrecker here...should be able to find one
Jun 24, 2008 at 5:35 AM
